Biloxi Trainer + build instructions.
leaded50
I had some bits of foamboard laying around, and found i can build a fast trainer of it.
I found a plan of a Piper Cherokee, nice plane, but this time wanted a high-wing. Well, a minor adjustment on top, and it got a highwing. :)
Changed resulotion to fit 27.5 inch wide wing. Easy made, one strip of foam inside as spar, 700mm wingspan, 140mm + 80mm wide wing made as easy FT builds.just "bendt over".
Fuselage was drawn up by how it looks from side, and cut out. A minor change on top for where the wing is gonna be ( removable) some formers or foamboard bits to shape the width to 35mm inside, then the minipod from FT, and a typical 1800mAh 3s will fit. Fuselage gest narrower in back. Bottom under the wing, and to front is foamboard, rest under is the paper removed from foamboard, also used on top rear, and front/ windshield of fuselage.
A fast trainerbuld in a couple hours, not a full plate of FT foamboard, and total without electronics, 175g.
Size at 700mm wingspan x 440mm length. 3 or 4 CH.
leaded50
found had some lightweight wheels.. and did the color. (more green under than it is.... its just a light dust..)
Yeah, ill try make afast build instruction with plan.
leaded50
building instructions/plan: Wing
Specs:
Wingspan: 700mm
length: 440mm
3 - 4 channel
(5mm foamboard)
This plane can be build with a high-wing, or low wing. (the original Cherokee have low-wing.)
part 1, main wing.
(section 4: change holders to top of wing , if build low-wing type. Or not necessay at all if glue wing at place as low-wing)
leaded50
Vertical/horizontal stabilizer.
leaded50
Fuselage.
( should keep scale by copying?)
leaded50
Fuselage. Internals eg.
