quimney
I've built two biplanes so far and had an opportunity to observe a third. In each case they seemed very sensitive to down elevator. The slightest bit of down elevator causes them to dive hard. Response to up elevator seems more normal. I have been searching the web for hints but can't find any articles discussing pitch stability specific to biplanes.
The ft baby blender was my first. It seemed very pitch sensitive even with a very nose heavy setup. The second was an SE5 of my own design (can be found in the mad scratchbuilders section). It flew better than the baby blender but it is still seems pitch sensative compared to all the single wing models I have flown. My Se5 has zero incidence on the lower wing and 2 degrees up on the upper wing.
The motor is mounted 2 degrees down and the horizontal stabilizer is also mounted 2 degrees down. Throttle climb is very mild but there is still a little so I don't think I
I went too far there...
Any help would be much appreciated. Thanks
