I have a frustrating problem with the elevator and rudder throws
can't get more thn 20° angle on the control surfaces
servo throws are ok the linkages are on the first hole on servos and last on control horns and the rod is ok...how the heak???
How much throw are you expecting? My elevator only goes 20º up or down... Anyway - try taking off the control rods and exercising the hinges by hand to loosen them up. If they are new they might be quite stiff...
The rudder control rod flexes a lot - which may prevent it from functioning properly. Try adding a guide so it doesn't flex as much.
Hey mick.
Yeah, as colorex said, those throws are right.
If you find that the controls are anemic though, moving the linkage up at the servo, or down at the horn will increase throw.
