Instead of creating a new thread, I'll expose a problem I encountered here, hoping that someone will read it
So, I've been flying my Mini-H for a week and a half now.
As a first FPV setup, and as a fairly inexperience pilot in general, I've been flying in level mode... I know, I know.
I had try to fly in rate mode before, but it was windy (20-25 kph gusts), and I had shamelessly blame my failure on the weather
Yesterday evening however, the air was perfectly still, and as I felt more confident in my abilities, I gave it another try.
The problem is, the quad had a bad tendency to pitch backward... I'm not sure what's causing it, so I'm asking you guys for ideas.
My first question is : how critical is weight balancing ?
I was using a 1800mAh battery, and while the quad was more or less balanced (the CG is somewhere around the middle of its length), being top heavy, the balance is quite unstable (if I hold it a couple millimeter more to the front or back, it quickly flips).
I then tried with a lighter 1500mAh lipo, and while it felt better, it still wanted to pitch back on occasions.
Then : can someone share their PID settings for a Mini-H running a Naze32, SS X2204 with GF 5030 (and a Mobius) ? I'm still using stock settings, and while there's no bad oscillation, I'm sure it can be fine-tuned better (I just don't know where to start).
I need to review the video from yesterday, I'll try to upload the bits where the problem happens.
But if any of you had some pointers, or have some ideas I could try to replicate (and hopefully fix) the problem, I'd be very grateful
Thanks !
Thanks !
