FinalGlideAus
terrorizing squirrels
I've had this little bundle of joy sitting in a box now on my bench for over a month and decided it was time to pull it out and start building. I ordered the mini quad early because I knew the stock levels would drop dramatically when it started popping up on the Flitetest shows. I was biding my time because I wanted to wait until the Fatshark Dominator HD's came out to buy my first set of goggles so I wasn't pestering others to borrow theirs but have got impatient waiting and will see what I'll do when the quad is done. Because of this and some other parts still on order it may drag this build out but I should at least have it flying LOS fairly soon.
My planned specs will be:
SunnySky 2204 2300kv Motors
BS12a ESC's but changing to KISS esc's when they come out
Gemfan 5030 but trialing HQ 5x4 Props
1500 3s 45c battery
Naze 32 Acro FC
AR600 rx
600TVL super had Board camera
ImmersionRC VTX
Super Simple OSD
I love my SS2204's on my Warpquad so happy continue on the BO quad. The 5030 gemfans are pretty standard but I''m interested to try the 5x4 HQ props. HQ makes a nice prop and should give the BO quad a bit more boggy. I have plenty of BS12a coming in the mail but am really keen to try the KISS esc's when they start production. I love the simplicity and light weight of just adding a satellite rx but because of the distance this thing can cover you need a full range rx and because of all that carbon you really need an rx with long antenna's and the ability to use diversity wisely. The AR600 has twin antenna with diversity and the antenna are long which allow smart placement. I'm planning on installing a basic OSD for battery voltage only.
First up the kit comes packaged very nicely and a nice touch is it being wrapped in "blackout" bubble wrap. Parts are individually packaged in ziplock bags and are in perfect condition. I must say the Carbon sheet used is some of the nicest looking I've seen and the cross section of the 3mm thick arms shows a very high quality multiple layer carbon layup. Those arms are not going to break anytime soon. On top of all this, the quality of the cnc cut's are of a very high standard which is a credit to Blackout's cutter. It is really hard to notice any cutting marks on it at all. Nice work Blackout! The PDB (Power Distribution Board) though is the star of the box. You can see the effort put into the design with many small great features that don't jump out straight away that make you think "good idea". Pretty much everything you need to wire up can be soldered direct to the board making things much simpler. The bolts and so on are of a high quality also which one would expect. A nice touch when you begin to assemble is to find the spare bolts in case you loose or break something for whatever reason. Although plans or instructions are not included, a business card is included with a link to the webpage where you can download them.
Tonight I did the basic assembly of the quad to get familiar with it but first I did some finishing of the carbon edges. The finish is really good and doesn't really need it but it's good practice to take off the corners as they are very sharp and can cut through the silicone shielding of wires and make bad things happen. This took a while to do as it always does but the end result is worth the work. Putting it together is rather simple and just a matter of bolting things together. Before I knew it the frame was pretty much together.
So far I'm really impressed with what I've experienced. The only downsides so far which are very minor are firstly the manual is not up to date showing the PDB and it's connections. There is plenty of info on the website but it is all geared towards the frame without the PDB. To be fair it's not hard to work things out but a diagram of the PDB and it's connections would be good. Secondly, there are no O-rings in the kit that go on top and bottom of the FC . I'm not sure if these were missed in making the kit or if they are not included at all it would be nice if they were included as they're not easy to find in small amounts like that.
Anyway, I'll update as I progress some more.
1500 3s 45c battery
Naze 32 Acro FC
AR600 rx
ImmersionRC VTX
Super Simple OSD
