I pulled my Blade 120sr out of the hangar and realized I have not made a set up for the aforementioned xmitters. What is recommended?
Thanks
Setup for the blade 120SR is pretty straightforward on either tx. Setup a fresh profile, you can either use airplane or helicopter mode. Use subtrims to make sure you have the swashplate relatively level. Next, check all your control direction and reverse channels if needed. Pages 8-9 of the manual provide some great directions on checking your swash directions:
https://www.horizonhobby.com/pdf/BLH3100-Manual.pdf. Don’t forget to check tail rotor direction as well! I also recommend setting channel 5 to 100%. That will give you max control throw, which this guy really needs.
As for the roll when picking up, the 120sr gets pretty squirrelly in ground effect. You will find it much easier to fly once you get it about 2 ft in altitude. I recommend waiting for a nice calm day, and trying this outside somewhere. Once you have it in a stable hover, trim it up, and you are set! Hope this helps.
