Arcfyre
Flying my 60" Storch-derived sport plane which has 4" oversized tires and a steerable tailwheel. Temperature here today is just below freezing, but it was warmer yesterday so the grass is wet, not frozen. Did two takeoffs and landings, and on my third approach to land (the final leg takes me over a pond) the elevator servo locked into full "up".
The nose came up sharply and I immediately applied power to abort landing and climb to safe altitude. Even with full down elevator input, I was unable to drop the nose. At full power, the plane did a loop at low altitude, but being unable to pitch down, it stalled and hit the water.
Prevailing winds blew it to the far side of the pond so it took about 50 minutes to recover it. The battery is still good, I'll need to test the servos in turn. The motor is likely fine, but the ESC is probably cooked.
I can only assume that some moisture got into the tail-mounted elevator servo during my first two takeoffs in the wet grass. The moisture then froze on the servo during my final approach, locking the elevator in position during that critical flight phase. Unlucky.
Pictures of the damage enclosed. Note the elevator frozen in full "up"
