meaured my plans, they were also exactly 1cm : 1cm.
I opened the pdf with full plans and let the pdf-reader split them and insert cutmarks. I didn't know if there would be any problems with scaling because i print on A4 size, and you probably desinged them for US letter-size.
Anyway printing the full size plans split up works really good for me. did that with the other FT plane I built, too (and with the one is tarted but never came further than cutting the plans out).
I just now looked at your tiled plans and saw all the cut-marks etc.
so maybe that would have been better to print, but now I already have the plans ready...
I REALLY like the way aou design your plans, Sponz! :applause: (why is there no thumbs-up simely?) especially all the labelling and the more detailledlines for the different cuts are totally awesome. since i print them in black/white it's much easier to see what to do than on the FT plans. With the baby blender i have built I made some wrong cuts and had to look at the build videos very often, since i cant see the colors of the lines. That's so much better with yours. Also you always know which template you hold in your hand after cutting since because of the labelling. Also I was quite pleased that there weren't any small parts of anything on an extra page (like the last inch of the fuse doubler on an extra page or something like that) I don't know if you planned that in advance or if it was just good luck, but if you did: thanks! There's nothin more annoying for me than have to cut out a teeny tiny part from an extra page and glue it to the big thing when this could have been prevented by moving the part half an inch on the plans.
so really great work there!
concerning the time I needed:
preparing & cutting the plans: three episodes of "Grimm"
- but if Ihadn't watched it would probably have taken me about 45 -60 mins
unfortunately I couldn't cut the foam yet since the foamboard I got is about one or two inches to small for the main wing
and I wanted to do it all in one go
(the problem is that foamboard isn't that easy to get here in germany and the bigger sheets are quite overpriced in my local shop for double the size you pay nearly 3 times the price) but I hope to get a big sheet and be able to build at least at the weekend.
