looking forward to your test, if it's going to work. maybe with thinner foamboard if it's to heavy? where I usually buy it, they have 3mm and 5mm to choose from.
...I should have ordered more 5g servos
Not sure if this is going to fly yet, but I figured I'd share it anyway.
Mighty Mini Baron...
It's 60% size of the original. 18" wing span. Uses the Flite Test Mighty Mini power pod. I may end up having to scale it up a little yet...we'll see. It is significantly smaller than the FT Mighty Mini Scout!
That thing looks good. When you fly, I am willing to bet that it will feel pitchy. That's just my opinion trying to beat out the test flight. If that is the case, a slightly longer fuselage should help. or shorten the chord but keep the leading edge in the same location.
I built a 15" span version of one of my scratch builds, it was scaled evenly but was very pitchy. I scrapped it without trying a longer trailing edge to stabilizer.
That plane is too pretty to scrap if it does not work the first time out.
Cool. I am looking forward to seeing flight video. My attempt at the smaller version of mine used the 9g servos and other gear from my regular builds. That's when I realized that my gear weight wasn't scaling down with the fuselage weight. I have yet to invest in smaller servos and motors, so I have been sticking with my standard size builds.
What motor do you recommend for those little builds? Is the same motor used in the Mini's acceptable? I was thinking of using one of these for my lighter builds. http://www.hobbyking.com/hobbyking/store/__5358__18_11_2000kv_Micro_Brushless_Outrunner_10g_.html.
I hope to add a Bloody Baron to the mix in time for Flite Fest. Looking forward to meeting you and flying together.
Whow I didn't realize HOW small it is, when i first read your post. (I didn't convert the imperial to metric size when i read them, so the numbers didn't were a clue)
I just realized it when I saw the picture next to the UMX plane.
I wouldn't scale it up. I love the mini-size. I was thinking about getting an UMX or HK fun fighter for quite a while, because I wanted something i can just throw in my backpack and take with me. That's going to be the mini Baron now
But now I can't decide if to finish the Tiny-trainer I started or directly using the electronics I planned for it to build the mini-baron![]()
concernign the twitchieness:
Aren't all those small planes quite twitchy? I think with enough expo and low enough rates you should be able to control it... at least I would try getting it under control first before sizing up.
and of course some questions
You have built it without Rudder, haven't you? I can't see that exactly on the pics (maybe I can find enough servos then to build it AND the Tiny Trainer without having to wait for new servos to arrive)
I was thinking about building it with a detachable wing - so just fixing the wing with rubber bands. do you think that would hold up? It would make it extremely transportable... so It would be easier to smuggle it into the car for the next vacation without my girlfriend noticing until it's too late![]()
...On my Bloody Baron I recently ripped the wings off it in flight...
LooseBruce
I'm sure that it would work. Just add some dowels/skewers like some of the FT designs, and you could rubber band it on. I would make sure you use the tab-and-slot location to help keep the wing positioned/oriented. I think that you would want to reinforce the tabs with some extreme packing tape to make the last longer as well. It's definitely a cool concept. If you try it out, please post some pictures and let me know how it works.
Bout the removable wing.
I believe the wing could be easily removable.On my Bloody Baron I recently ripped the wings off it in flight (not easy to do by any means). I considered making the new installation removable but finally decided against it because it is not that long of a wing.I think it would be easy to do though. You could even use the bamboo skewer in the fuselage for the back connection of the rubber band. Very nice mini build you have there.
LooseBruce
I would also like to ask: HOW!?...On my Bloody Baron I recently ripped the wings off it in flight...
