I just finished my first Bloody Baron (except for the Vert Fin decal) and I can't wait to test fly it.
I used my 3D printer to make a plastic nose and cowling which looks something like a Fokker DVIII, more or less. I can't guarantee you could retrofit the nose to an existing BB, but you could try. I did my best to stay faithful to the original plans, so in theory the aft edge of the 3D p;printed nose should match up with an existing fuselage. I'll post the STL files to Thingiverse in the next few days with a Bloody Baron tag.
Basically I just cut off the standard nose just ahead of the wing leading edge and attached my plastic nose with hot glue. My nose has some rails extending back along the inside of the fuselage to enable me to add a foam board "shelf". My ESC is above the shelf and the battery is below the shelf held in with Velcro and a strap. The RX is fastened to the top of the fuselage with 3M trim tape just aft of the shelf with the Elv and Rud servos aft of that.
I stripped the paper off of the fuselage components and replaced it with colored packing tape on the outside only
I stripped the paper off the wing and used 3M 77 spray adhesive to glue on some home made German WWI lozenge camouflage and then I covered that with clear packing tape. The inside of the wing is bare foam. The wing skins were printed on tabloid sized bond paper in four parts. I attached the skins and clear tape before folding the wing.
The wing has a carbon fiber arrow shaft spar with a 1" wide DTFB spacer pad (no paper) above and below the spar.
I also 3D printed some light weight protective skids for the exposed bottom edges of the fuselage.
With an 1800mah 3S battery positioned so that battery midpoint is at the leading edge of the wing, my plane balances on the standard CG marks.
