Lee.dan1989
Bloody Vought Plans Beta Release
Here we go! Welcome to round II of the Bloody Saga... WWII, That is! Attached are .pdf’s of the Bloody Vought Corsair Plans... AIO and a tiled version. *The 6” Scale marker is on the first page, so you can print it first to double check your print settings. The build is identical to the Baby Baron, as are the electrics set-up and recommended control throws. More details, build photos, and videos are coming soon! ENJOY!
Hey what are the recommended rates and expo? Also do you have a skin for the dh vampire yet? Cheers
Lee.dan1989
I have just stumbled across this thread these planes looks awesome, so well done guys, I'm going to build the vampire has any1 else built this plane?
FoamyDM
Building Fool-Flying Noob
I built and designed it. When i did, I ran out of 5g servos, and put 1 - 9g at the front of the wing for balance. I then ported them through linkages. The the surface. If you can just put in servos in the wings.
Also CG is at the front of the booms.
Lee.dan1989
Thanks I'll give it a go is it a handful? Cheers for the speedy reply
FoamyDM
It is small build, so the wind will be in control. Balance might really be the hardest part.
My first underpowered toss with the edf was pretty good, the second with the prop was hard it showed off the weaknesses of the linkages.
let me know how this goes. :)
Lee.dan1989
Cheers 😜
I did build the p40 last night with corroplast I'm pretty impressed with the simplicity, looking forward to maiden. I'll update you on the vamp build.
Javiester
taking advantage of the quarantine I will try to scale the P-38 Lightning to a larger scale
I will use the plans of the XF Brit and the Baby Brit to see if it helps me to orient myself
I like how it flies
Lee.dan1989
Oh kewl I printed the corsair out and it looks rather big well see how it turns out loving the simplicity of the plans. I have a 75% p40 ready for a maiden so weather depending tomorrow should be the day
BossBluff
Simple is fast.
Thank you
I will do , I have also just built a stuka they both need some colour and decals do you have any low wing designs yet? Nice work
no low-wing designs yet. I’ve been working on a couple new projects, but considering my pace the last couple year’s (work and other dad stuff 😜) I’m going to keep them under wraps until I actually get them finished. 👍🏼
Lee.dan1989
Yeh I get ya the daily commitments, well I hope to be able to test out your creations whenever that my be. The wind has picked up today , hoping itll calm so I can maiden the p40, I'll post some pick later today 😜
Javiester
I don't know if it's okay or not, I'll see when I can go out and buy foam board
I leave you the plans, they are modified with the inkscape which is the only program that I manage a little
If someone tries it and or verifies it, please communicate it, I'm not sure that everything is ok
I have mounted everything in a pdf and it seems to match
I've called it XF Bloody lightning
  • XF Bloody lightning 1.pdf
  • XF Bloody lightning 2.pdf
  • XF Bloody lightning.pdf
danskis
This is great. I've got all the parts and I've been wanting to do a project using a "skin" These small projects are just what I'm looking for.
I'm about to go to Staples to print the P40 skin. Besides making sure I tell them to print at 100% does anyone have any suggestions to avoid confusion? How about the copyright thing, has anyone had to deal with that?
Lee.dan1989
80% p40 and 100% stuka
Javiester
I have a question about him
Bloody lightning
Is the single-engine version tilted down?
and if so, why does the dual go straight?
thanks
