remzak
It's been a while. I'll admit, I haven't flown fixed wing since last Flite Fest and certainly haven't built anything. But here we go, now that school is over BOB v4 is in progress. Let's jump right in.
First things first, here are my thoughts on last year's build:
Pros:
Biggest I'd gone yet, with decent construction quality. I was specifically happy with the fuselage and tail, but the wing was okay.
It was a tank in the air, almost impossible to take down. See photo: ( That's 3 planes stuck, a nutball that just bounced through a motor, and contact imminent)
Landing gear allowed takeoffs. This was a big one, hand launches in the previous year had just gotten too sketchy.
Cons:
Super lacking in power, keeping it in the air was a constant struggle.
Insufficient control surface size made it challenging to fly and necessitated planning of flight paths, made recovery and wind gusts hard to manage.
SUPER heavy tail, made the center of gravity a huge struggle and I was flying with POUNDS of dead weight through the entire event.
The landing gear was sketchy and broke frequently. Did its job, barely.
MY SOLUTIONS:
So, to address the cons (and because I never bring BOB home) I'm doing a full redesign.
First, the biggest thing I want to have this year is sufficient power. To this end, I'm getting rid of the Emax 3520 925kv motors that served me faithfully for 2 years in favor of Propdrive 5060 380kv motors (double the size baby) on 6S. This should get me the thrust I need to keep this thing in the air, and keep things exciting.
Unfortunately, this means I need to buy new batteries. I'd been running two 4S 6600mah packs for two years, I'm going to be swapping to four 3S 5000mah packs in parallel and series for a net 6S 10000mah pack, with a dedicated 6S 5000mah on each side. ESCs can stay the same though, which spares my wallet slightly.
I'm starting the build earlier this year, which has given me more time to plan. Larger control surfaces are certainly in the works, and proper landing gear will be a priority.
Expect more updates soon, for now, I'll leave you with some rough sketches I did while on a plane a few days after last year's event.
Rough Stats:
Wingspan: 150 inches
Chord 26-30 inches
Length: 96 inches
Width: 18 inches
This tail is still hopelessly overbuilt, I'll fix it in Fusion 360 later.
Don't like this spar design, but I'll expand on my plans in follow up posts.
Pros:
Cons:
MY SOLUTIONS:
Rough Stats:
Chord 26-30 inches
Length: 96 inches
Width: 18 inches
