You can re solder the wire together, you have to clean the wire because it is coated with a thin insulation, just sand the wire to clean copper color and solder back together, should work fine.
Success! Soldered together and motor starts up fine. Now since so much of the wire insulation was removed there was no way to put heat shrink on prior to soldering. What is the best way to now cover the exposed wire? Just use electrical tape or try to find a larger size heat shrink that will slide over the bullet and still shrink down?
You can use tape or find larger heat shrink, harbor freight good source for it or if looks don't matter hot glue will work as a insulator and you can color it with a sharpie marker.
