randyrls
Randy
I have a Power Pack "B" twin for my Bronco. WHAT A BEAST! Flies straight and level at only 20% throttle. It will accelerate going STRAIGHT UP at full throttle! With 9x4.5 props it will climb right out of my hand, all I have to do is let go. That is the good news. The "B" twin needs a 3700 3S 30C battery to supply current draw. 2200 3S 30C doesn't supply enough power. I want to use 2200 3S 30C as I have more of these for other planes.
I want to reduce the current draw using one of these scenarios:
1. Use 8x4.5 props with the "B" motor to see if the current draw goes down enough for a 2200 3S 30C to supply enough power. I have a watt /current meter.
2. Use 8x4.5 props with "A" motors to see if flying characteristics are good enough.
I have a Power Pack "A" twin and some spare 8" props on order now. The 8" props will keep the props from hitting the ground (grass) when landing.
