Hello,
I'm trying to test different propellers. I have built a small wind tunnel. I'm using a RCX 1804 brushless motor with a ZTW Mantis ESC. ESCs can be controlled just like a servo. I have an Arduino and breadboard set up with a potentiometer. When the potentiometer is adjusted, the Arduino sends a command that would move a servo to a different position, which correlates to a different speed on the ESC. I had the whole system working a few weeks ago, but am now running into trouble. When everything is connected, the motor won't spin until full throttle and then it goes to full throttle. There isn't a problem with the Arduino given that it can still control a servo and that it is able to control the ESC. Before, I was able to adjust it from start slowly increasing the power. Does anyone have any ideas of what could be wrong? I feel as though if there were a bad connection between the motor and ESC that it would stutter between two phases which happened before.
Thanks,
Nick
Thanks,
Nick
