If we made a cabin section where the top of it is part wing, your idea might work and no dead space.
I don't understand what you mean.
If you added a third pin, then your idea of having the spars round would work. Not sure how to connect it to the fuselage though. Probably some hobby plywood with a hole drilled in it for the spar to go through. Which might end up making it closer to a mid-wing at that point. Or I guess make the top of the fuselage wood (for strength) and then a... clip, for a lack of a better word. I guess U-bolt is a better word.
Internet photo of the "clip" I'm thinking of:
I don't feel like re-drawing it, but exactly what you're talking about, but with a third pin that stops it from rotating that goes into some hobby plywood that is on top of the fuselage, would work. Actually, I guess you don't need the third pin. The removable one could stop the wings from moving at all.
Everything in the "system" is going to see a lot of stress, so it's going to have to be rather heavy, but it shouldn't weigh too much as it's just a fancy spar. The spar doesn't have to run the length of the entire wing though.
Anyways, I'm thinking that the final plane would look like the Bird Dog.
The nice thing about the Bird Dog is that it has a lot of windows on top of the fuselage, so just keeping that wide open would keep the look of the plane. And now that I think of it, allowing the wings to rotate will stop them from hitting each other so the wings can be closer together. There will still be a "dead space" though.
