Build Advice
AndrewRS
Hi everyone, I'm new here and not having a lot of luck with the search feature to find an answer about my first build.
I found the link to eCalc...but it is very in depth and I don't know what most of the things on there are so I really am unsure how to proceed there.
However, my question is this. I have the electronics from an e-flight plane. The Hobbyzone Champ S+. The motor is a bl180 2500kv and it has a 5x2.5 propeller. I have 2s batteries for it.
Would this work in place of the A or F power pack kits here? Could I use the existing propeller with one of the MIghty Mini designs, or should I get a different propeller?
AndrewRS
You can easily make a trainer with a flight weight of 100 g and a wingspan of up to 80 cm. The main thing is that the hands grow from the right place, and there are working brains in the head. https://www.rcgroups.com/forums/sho...lu-Baby-Primary-Trainer-**-Plans-Pics-and-Fun!
The plane that the electronics came from had a 27 inch wingspan and weighed 100g.
I was looking at the mighty mini scout which is 24 inches and just over 100g. I'm guessing that if I get a propeller with the recommend specs than the motor should be good as well.
I agree with bisco, that should be fine.
Here are some guidelines that may be useful on your next project.
The amount of thrust needed from the motor & prop depends on how you want to fly. A slow flying trainer, the thrust will need to be 60-80% of the weight of the plane. A typical plane, 80-100%. A war bird or one with a little zip will be 100-150%. A 3D plane will need 150-200% thrust to plane weight.
Watts per pound is another useful guideline. You'll need to weigh the plane and estimate the weight of the motor and battery.
• 50 to 70 watts per pound is the minimum level of power, good for park flyers and lightly loaded slow flyers.
•70 to 90 watts per pound is perfect for trainers and slow-flying aircraft.
•90 to 110 watts per pound is good for fast-flying scale models and some sport aerobatic aircraft.
•110 to 130 watts per pound is what you want for advanced aerobatics and high-speed aircraft.
•130 to 150 watts per pound is needed for lightly loaded 3D models and ducted fans.
•150 to 210+ watts per pound gives unlimited performance for any 3D model.
Here is a FT thread with more information.
Bricks
Changing props may be an issue as if I remember right that prop is a press fit not like most motors that have a nut holding on the prop.
