Build from scraps or new bundle?
doubleohomer
Looking to come back to RC flying after several unsuccessful attempts in my younger days. All those prior attempts have left me with various RC gear to potentially build from. Looking for advice on if it is worth cobbling together from my existing parts or starting fresh with an FT bundle for maximum success.
I have a few FM controllers including a 4-ch hiitec plus handful of hs-55 servos, some other micro and standard servos. 2.4ghz radio from a Honeybee V2 helicopter. For motor/esc, I have a Great Planes Rimfire 370 (28-26-1000kV) and Electrifly SS-12 or SS-25 Esc.
Goal build would be park flier +/- swappable power pack (think my motor/SS-25 would be okay for a B equivalent). Want something to learn/grow with.
Any suggestions or advice?
Part of me really feels like building from my existing parts makes sense but the other part says older radios and variability will lead to another failed attempt to get flying.
Thanks! - Confused in SE Ohio.
RickHunter
That motor and esc should be fine on a 3s setup. The servos depend on the build. I'm not a fan of plastic gear servos myself, but used them for a few years until going with all metal gear servos. Be careful on the micro servos on bigger planes, but they do work on small ones okay. If your just getting back into it, I would start with stuff you got before spending money. Just test everthing first and no propeller on the plane for testing. If it ain't broke, don't fix it (in my opinion).
Foamforce
Using what you have will save money. Starting with new will make it easier to succeed, because any time you do something a little different, then the online tutorials don’t some to your situation. That said, if you ask enough questions, most of that old stuff still works fine.
telnar1236
Yeah, I'd second the recommendation to build one with what you have. The power system and HS-55 servos should be perfect for a lot of Flitetest designs. You might want to consider a new radio and new batteries. Trying to get a helicopter radio to work with a plane could be a pain, and old batteries can be dangerous if you aren't careful with it.
Yeah, if you don't spend a ton and don't care about having a ton of features the FS-i6X is only $50-60 and gets the job done! (Not super fancy but has 10ch, mixes and has plenty of range for flying line of sight)
doubleohomer
Fantastic feedback and yikes! sorry for ghosting my own post.
Figure there will be some hiccups with getting the old gear running but definitely easier to swallow if I destroy something that has been sitting around unused vs. brand new. Going with a new radio and keeping the rest as is +/- servos seems like a good balance. I will check out the FS-i6X. Never owned a radio with the ability to load setups; is this something worth pursuing to increase the flight dynamics?
Batteries I have are a mix of old and new, will be sure to test before charging or pushing them and charge in a fire bag.
For model, any recommendations for a stable park size flier based on my power unit?
Thanks all!
tomlogan1
+1 on the FS-i6X with a caveat: it only supports 3 mixes per model. May not be an issue early on, however, if you end up with many optional features like flaps, retracts, independent ailerons etc,. you could run out of mix capacity. Also you may want to source the receivers that are 10 channel. Overkill early on, but you will be glad to have them in the future. A 10 channel receiver can support a 4 channel plane but a 6 channel receiver cant support a 7 channel plane. I know whereof I speak as I have a 6X and several receivers. Should you later on graduate to a larger transmitter, the Radiomaster TX16S supports the Flysky FS-I6X and smaller Flysky FS-I6 receivers.
RickHunter
I agree with @tomlogan1 about the transmitter. If you can afford it get at a better transmitter. You'll like it more in the long run. With that said there is nothing wrong with the fs-i6x and it will get the most the jobs done. Plus I do believe even though it comes factory with 6 channels, you can update the firmware to 10 channels.
31SamCoMi
I have only had experience with Tactic (which was discontinued 2018), but personally, Flysky or Radiomaster (specifically the pocket) sound great. However, concerning Radiomaster, I have heard that EdgeTX it not at all beginner friendly.
