Im putting together a guide to help you build and fly a EPP type 3D Plane from the plans you can download on the forum
So here are we go with the pictures!
Step 1. print all the pages of the plans and tape them together
You can cut out sections of the plans and then tape them over the foam so you can cut out the different parts
Go slow this is not a race and make sure you use brand new #11 blades I change my blade after cutting out just the wings and the fuse! the foam makes them dual real fast
Use a Medal Ruler when you can to make sure your cuts are straight
Repeat until all parts are cut out
(remember go slow and be careful)
Test fit the parts as you cut them out to make sure parts fit as you go.
Cut a bevel on the control services.
