Building a model and connecting everything, DON'T INSTALL THE PROP!
randyrls
Randy
When I am finishing the installation of electronics, before the first power up, DON'T INSTALL THE PROP! I have had the prop start spinning because of crossed wires. I have a twin prop (Bronco) that has a "kill" switch at the rear of the plane. I plug in the battery and then reach from behind the plane and turn on the kill switch. It scares the bejesus out of me to plug in that battery between those two spinning meat slicers!
If you must, have a prop on the plane to check if the rotation is correct, use one that is loose and don't tighten it down - just let it rest on the prop shaft, with no retaining nut.. Just crack the throttle, verify the direction of rotation, then shut down and remove the prop. Don't go to full throttle, lest the prop take off across the workshop!
Good points, LitterBug & Bricks. as long as the motor bell is 'touchable'. I used to use Popsicle sticks, drilled out for a loose fit, on my Speed 400 motors, but that was a long time ago. :)
MadMonkey
Early on after switching to Radiomaster from Spektrum I yeeted a plane off my workbench when I accidentally reversed the throttle 😆
I also had a note published in Model Aviation's safety section where I had a quad jump into my hand from a silly mistake.
Y'all be careful. A few seconds of extra work can save you from a lifetime of nerve damage. I've used APC props as knives in a pinch, they're no joke.
Edit: and another thing, don't risk using damaged props, especially on larger motors. The vast majority of the time, when an engine throws a prop blade, it'll turn sideways and dump its energy pretty quickly. But, aerodynamics, like firearm ballistics, does funny things sometimes, and I've seen a prop blade arc 20 feet like a spear and punch a hole in a metal roof.
My brother has done that and he was hold on to his airplane by just the rx wires! :ROFLMAO:(Thankfully it was just a little 2204 that didn't have that much thrust..Still startling though!😂😂)
Patriot Rc
I also had it happen with my mini scout last build-ruary. I had my 2306 on i with 4s. I turned off the remote when I got in from flying, and it went full throttle! (I must have had the failsafe at 100% throttle). :oops: 😲:LOL::LOL:
