Stealthily building an F117 community designed plane
CarolineTyler
You know that feeling, you're waiting for a plethora of bad weather to go away, a model that you have ordered back at the beginning of February to turn up at your door (currently stuck in customs I'm informed) and you see a design that just seems to cry out to be built.
This is a 64mm EDF F117 designed by Matagami Designs and from their maiden video flies real nice.
Anyway....enough chit-chat, lets's get this moving!
64mm 4S EDF ordered - It has 11 blades so should have a nice whoosh.
50A ESC ordered - the max draw of the EDF on the spec sheet is 52A static so that should be just peachy.
Plans printed
Plans glued together
Components cut out
Grabbed the only 4 Flitetest foamboards I have in the house and with some tetris skills - laid them all out
Next stage I do is to use mounting spray adhesive and gently stick the paper to the foamboard. I treat my plans as disposable as I can always print more and I feel that it's more exact since I'm not adding another level of copy/tracing that would be needed if I want to reuse the plans as templates.
Matagami Designs
Plans printed
Components cut out
Legendary tetris skills! Good luck!
The Fopster
Plans printed
Components cut out
That really is ninja level Tetris. Kudos 👌. Good luck with the build. I got a 50mm edf from Santa so just deciding what to build. Grunjet is the only sensible choice, but Grifflyer's F22 looks amazing and would fly off my fan. Decisions...
Good luck with your build. With your track record I suspect it will be "quite nice".
The Fopster
50mm EDF you say? - I can completely recommend this L-39 I have mine flying on a 4S 50mm EDF and it always gets admiration at the club field......
I've looked at that too! I'm an OK builder but dodgy pilot (not much opportunity to fly) so I need something easy to fly and easy to repair. Only sensible option is (I think) build a grunjet to build up stick time then build something fancy later on. In the meantime I just downloaded Picasim...
Happy building!
Ratcheeroo
Happy building!
I just happened to have built 2 L-39s, easy build, easily repairable as well would be my guess also. Just downloaded the F-117 so I'll be following this build start to finish to see what I'm in for. Grifflyer says the L-39 is a good trainer jet , but the Grunjet looks interesting also. Good luck to both of you!
CarolineTyler
The L-39 flies super smooth, just make sure it has a good speedy launch throw, I have a launch switch on my transmitter that adds about 15% up elevator and that has made launches much better.
F117 parts all cut out.
Won't be doing much more on this build till next week as I have that Arrows Hobby Viper Jet coming in the post tomorrow and I plan on swapping out the ESC for a 40A one for 4S capability.
Also adding a rudder, I like rudders :)
Ratcheeroo
Awesome thanks for the tip, my experience with the F-22s had me thinking I should probably be doing something like that. Nice work on the cutting, nice clean work!
CarolineTyler
This build is coming along....
Decided to replace this front EDF support with one cut from balsa which I strengthen with a couple of layers of fibreglass bonded with 5-minute epoxy.
Just pondering over whether I can now close the wings....
Wings closed up and it's becoming a thing....
Oh darn, just realised I haven't put the servo arm screws in :(
Little bit of wing surgery needed :)
