Hi all,
I've been lurking here for a while and wanting to get involved in this hobby even longer. I've finally decided to dive in and I've already purchased a RTF high-wing trainer to get my feet wet. I'm waiting for my local club to have their next gathering so that I can go learn a little bit from some more experienced people.
But, assuming I crash that plane I would love to have a simple (easily fixable alternate). Plus I would love to build my own plane! So I've decided to try building the Old Fogey or the Bloody Wonder (or maybe both). I've looked around and tried to find all the bits and pieces that have been recommended to get started. Since I'm starting from scratch, I've had a little trouble figuring out just what I needed to buy. Would you guys mind reviewing my first round of buying spree below to let me know what else I may need to go out and find for building my own planes?
| TX/RX/Servo | Quantity |
| HobbyKing HK6S 2.4Ghz FHSS 6Ch Tx & Rx (Mode 2) | 1 |
| HobbyKing HK6DF 6 Channel 2.4ghz Channel Receiver | 2 |
| HXT900 9g / 1.6kg / .12sec Micro Servo | 10 |
| Motor | Quantity |
| hexTronik DT750 Brushless Outrunner 750kv | 1 |
| TURNIGY Plush 25amp Speed Controller | 2 |
| NTM Prop Drive Series 28-26A 1200kv / 286w | 1 |
| NTM Prop Drive 28 Series Accessory Pack | 1 |
| NTM Prop Drive 2826 Series Replacement Shaft | 1 |
| NTM 28 Carbon Fibre Motor Mount | 1 |
| Battery | Quantity |
| Turnigy 1300mAh 3S 20C Lipo Pack | 2 |
| Turnigy 2200mAh 3S 20C Lipo Pack | 3 |
| Turnigy Accucel-6 50W 6A Balancer/Charger w/ Accessories | 1 |
| HobbyKing HK-010 Wattmeter & Voltage Analyzer | 1 |
| Accessory | Quantity |
| SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag) | 3 |
| 3.5mm 3 wire Bullet-connector for motor (5pairs/bag) | 2 |
| XT60 Male w/ 12AWG Silicon Wire 10cm (5pcs/bag) | 1 |
| XT60 Female w/ 12AWG Silicon Wire 10cm (5pcs/bag) | 1 |
| JR Type Male Servo Lead 26AWG 15CM (10pcs) | 1 |
| Simple Prop Balancer | 1 |
| Lithium Polymer Charge Pack 18x22cm Sack | 1 |
| Linkage Stopper D1.8mm (10pcs) | 2 |
