Maidened this morning. Did not go so well.
The airplane wanted to roll left. Added right aileron and found it had no effect. So compensated with some trim and rudder. It also wanted to dive. Compensated for this by holding a bit of up elevator. The roll kept worsening. Trying to line it up for landing, it got to the point I was all over the controls. Went into the alfalfa...flat. But, still took the gear off and broke the prop.
When I got to the airplane, I did a quick control check. I immediately noticed the issue. Up elevator caused the left side of the elevator to deflect considerably more than the right...thus causing the left roll. It acted like an elevon.
everything else seemed fine (again, other than the gear and prop.
I think I’ll add a Stiffener between the two sides of the elevator. I’ll probably increase the throw on the ailerons a bit as well.
Oh well, they’re foamies!
