with these short coupled planks. I'm finding them VERY challenging to get the Balance point correct.
I start with a CG point at around 10 to 15 % of mean cord. Ensure that I have plenty of elevon movement and start with hand launches. Later I move to bungee launches but the launch speed is increased only after success at lower speeds. Note with the short coupled nature of the elevon control you do need to start with plenty of expo and a gentle touch on the sticks! I am somewhat lucky as I started into planks with absolutely no knowledge and so I had to learn quickly and whilst challenging they can really perform. Having no tail means that they can really turn "On a Dime". If setup with differential the smaller span birds can do axial rolls at a rate that still astonishes me!
The reflex I start with is marginally above zero as it is initially better to have the craft want to dive SLIGHTLY. I hold the up elevon manually until I get a glide that I am happy with and then I adjust the reflex to be the same as I am holding for a good glide. Once glides are good and stable you can do your stall glide tests to check the balance point.
After the BEST CG/balance point is determined you can revisit the reflex settings and this should be the final adjustment.
On this bird the starting balance point is around 32 to 35 mm from the wing LE at the wing joint.
If you want a simple plank design, (accent upon simple build and good handling), I did a thread of a goblin like plank a while ago and I could search it out for you, (mine is still flying!). But then for a bit of extra complexity you could just build the FT Goblin, (a nice bird but a little heavy and complicated).
Have fun!
