I high started my sister's stock simple soarer with either 4 or 5mm surgical tubing and 50m fishing line. I launched it pretty hard and got the full high start length of altitude, but folded the wings on about the 10th launch. I guess if you take it back a notch and accept less altitude it should handle it (at least for more than 10 launches). I'm sorry to hear about you Bird of Time, they look like a nice glider. Do you remember how big the spar caps were and the spacing between them?
Thanks for the info.
So its not too onerous to put ply or CF spars into the foamboard wings, even as a retro mod, but let’s face it making a new wing is only half an hours work anyway.
I was thinking 4mm so your experience is valuable.
The Bird of Time was from a short kit so the wing was stock design.
I narrowed the fuselage for SD100 servos and lightened the tail a bit as I HATE lead in the nose.
It was built as a lightweight thermal for a club competition so on reflection (hindsight being the exact science) probably needed CF spars for hi-start.
The Finger Vee with MH32 section instead of Clark Y, a narrowed fuselage to minimise drag and with SD100’s (my favourite servo for small stuff) and tail surfaces built up from carefully selected balsa was an awesome flyer.
One of the best traditional balsa glider designs I built.
I’ll dig an image out.
