Bush plane build challenge
Ketchup
4s mini mustang
I know that I already asked the question, but I wanted to know if I needed to make a single one take video for the payload challenge. I would show all of the flying and I would show how much weight is in the plane at max capacity, but I might need to make a small cut in the video while messing with weights and getting them in the plane. I might also have to do some math too.
Raccoonworks
Save your Trash!! Myles
So I got the Pc-6 back! The nose is gonna need rebuilt, I'm gonna need to build a new powerpod and the landing gear needs a little bit of work. But everything else is fine! She'll live to see another day!
Ketchup
4s mini mustang
All right... I am gonna try the payload thing in another couple hours and I guess I will just try to do the best I can for video. Right now I'm gonna go weigh stuff so that I can add everything up while I'm there instead of having to come back home first.
mdcerdan
I think you can use water. Easy to measure volume in the field. Then at home you can weight the volume of water you use in the flight.
Ketchup
4s mini mustang
I already prepared weights a while ago so I am only weighing to be 100% sure of their weight. Water is a pretty good idea though...
Ketchup
4s mini mustang
I just went out and did the payload challenge! The plane carries 1323 grams and weighs 870 grams so the ratio is 1.52. I have some homework and stuff so it might take a couple days to upload a video. Also, while trying to do the challenge I severely damaged one of my wheels, so I can still make a new set and it will still be ok right? Other than that I have a little more gluing and reinforcing to do since I found a minor crack in the fuselage but that is really it.
Edit: I wrote 1320 as the max capacity but it was really 1323 so I changed it.
