Bush Plane Challenge III, 2022
Matthewdupreez
I’ve got a V2 all worked out that I just need to build here shortly. Once i start working again I’ll buy some servos and a receiver and see where that gets me. Have all sorts of little changes that were done, and a few more I need to add before i build it
Please do drop me a pm with the v2 plans. I'll beta test them.this weekend for.you.
Hondo76251
I think it might be hard trying to get a 5 kg plane off the ground lol. @Hondo76251 if I usually fly with a smaller battery, is using a bigger battery counted as extra weight?
Yes, the weight can be anything.
The idea is, you do a flight at the lightest weight possible, then add weight by any means you want and fly again. The difference in those two weights is your payload.
Ratcheeroo
I'm gonna call that done. :LOL: It's as good as its ever going to look. That is the first time the wings have been completely seated into position. Ailerons are wrapped in vinyl as well as the wing center and the wings are friction fit. I have it set up for flaperons as well. Hopefully I can give it a go this weekend.
