I am still learning the basics of E Motors and power systems. I am looking for a C pack size motor replacement and I am wondering if this motor would be a good choice.
MultiStar Viking 1308-4100KV Brushless Outrunner Drone Racing Motor (CCW)
Here are the specs listed with the motor:
KV(RPM/V): 4100KV
Battery: 2~3S LiPoly
Max current: 200w
Max Amps: 16.7A
No Load Current: 1.3A/10V
Internal Resistance: 0.11ohm
Number of Poles: 9N/12P
Dimensions(Dia.xL): 13x8mm
Motor Shaft: 3mm
prop shaft: M4
Weight: 14.3g
bolt hole spacing: 12 x 12mm
Lamination thickness: 0.2mm
Magnets: N50SH
Balancing spec: 0.005g (or better)
What size ESC for this motor?
I would like to build the Simple Cub and/or the Simple Scout
Will an 8/4 to 8/4.5 prop work for this setup and these planes?
It states a 2-3s LiPo, what Mah will get me about 10 minutes of light time?
Thank you for your help and suggestions
KV(RPM/V): 4100KV
Max current: 200w
Max Amps: 16.7A
Motor Shaft: 3mm
prop shaft: M4
Weight: 14.3g
Magnets: N50SH
