Cad help
breh
I'm trying to make a foamboard aircraft that resembles SpaceShipTwo, and want to use cad. the problem is, there are no tutorials on how to use cad.
DinosEatPeople1
There is always a tutorial on how to use CAD but you need to know what you are using first. If you want something basic and free, Inkscape. If you have money there are much better things to use. If you put in enough time and effort into something it can be done. You may just need a direction to look. And being completely honest with you you may not need CAD to build an airframe all you need is something to go off of. Like a picture on paper to scale up or a full size 3 view. But more information would be helpful in assisting you
Ketchup
4s mini mustang
Like Dinos said, you might not even need CAD. If you do though, then first pick out a CAD that you want and search YouTube for tutorials. I personally use doublecad and I know of a good tutorial that has enough to get you started. Then there are things like Inkscape, freecad, autocad, and probably lots more. They probably all have tutorials too.
breh
I may have found a few tutorials on cad. If you want to know which cad I’m using, it’s fusion 360
DinosEatPeople1
Well then sir, in my humble opinion, you have some of the best of CAD software! I know that there is a master series design help thread on the forums that may assist you. This is now out of my expertise so good luck!
breh
I've been working a lot on Inkscape, until whenever I use the Bezier curves the line starts out thick and goes thinner. Is there a solution to this?
