Can I fly with upside down motors?
DavidtheDJ
Casual Crasher
Hello,
I am thinking about trying to make a 3D printed quadcopter frame thats small and thought, why don't I make the motors mount upsidedown but with the props rightside up? I looked around a bit on google but I'm not sure if others were saying what I was thinking. So what would propblems be other than landing gear if the battery was mounted lower than the motors?
To help see what I mean, this is a link to a very quick design I made up:
https://tinkercad.com/things/5BreCe09drD
Thanks!
DavidtheDJ
Casual Crasher
Thats nice to hear and yes I will be considering landing problems as this was just a idea. Those expample do look good as ducts may also increase the overall thrust.
Thanks for the response!
AndyP57
You would need to take of fairly quickly after connecting the battery to prevent the electricity dripping out of the inverted motors. Maybe landing in a tray too to stop the grass getting contaminated with remaining volts.
DavidtheDJ
Casual Crasher
Oh yes of course, I wouldn't want to waste runtime or effect the envrioment around me. I could even try to make the motors have a built in tray so even in the air I wouldn't be dripping unused juiced from inefficient motors.
SnowRocker88
Amateur pilot and builder
It's been done before. Heck, even some commercial designs run inverted motors. On the commercial models this makes it so the arms themselves can be formed into both prop guards and landing gear as a single unit. Not sure why one would be inclined to do so with a DIY but I'm sure someone could find an advantage to it.
ElectriSean
Eternal Student
I have the Nano QX2 with this design, a couple things I've noticed: It almost always lands upside down, and it is impossible to take off from grass or even gravel, the rotors hit everything. Now if they could make it take off upside down, they might be on to something ;)
Run in 3D mode... Take off inverted then flip over to "normal" orientation. ;)
Cheers!
LOL!
I like the upside down motor look. I say go for it.
JimCR120
Got Lobstah?
Site Moderator
Another Motor Upside Down Option
Hello,
Thanks!
I saw your question the other day and once I had a little time found the video with which I wanted to respond to you.
Watch the whole thing or fast forward to about 3 minutes to see how the motor can be upside down but the props still on top, another option you might want to consider.
jipp
interesting. i would not of thought of that way of mounting them. i wonder if his prop savers has caused any crashes.. id imagine if he pushed it they cause problems like when you push it and a prop breaks in mid air. but maybe prop savers are ok. dunno.
chris.
