Can I use other recievers with my flyski radio
Foam Addict
Squirrel member
No,
you do have to stay with flysky.
I have a friend who uses these in combat planes, and doesn't have any range issues
http://www.hobbyking.com/hobbyking/store/__36509__Hobby_King_GT_2_2_4Ghz_Receiver_3Ch_USA_Warehouse_.html
He also uses these in every thing but his EF-1 racers.
http://www.hobbyking.com/hobbyking/store/__36721__Turnigy_9X_2_4GHz_8Ch_Receiver_V2_USA_Warehouse_.html
EDIT: Sorry, I should have said rebranded, and my pictures are out of order.
Tritium
Amateur Extra Class K5TWM
Technically yes, flysky or a re-branded equivalent such as Turnigy 9X and others.
Thurmond
CrashRecovery
I'm a care bear...Really?
Ok I'm just thinking about doing some micro stuff for inside flight and was looking at the alula and it says a micro receiver.
aiidanwings
For a some what micro FlySky rx, you can remove the case. That drops the weight from 9 grams to 6. The cool part, you can do this with foam board-
Also, the flySky will bind to WL Toys and Syma micro receivers. I haven't actually used one in a plane... yet. It's on my to do list.
510thousandths
Just someone else.
I have the alula and have a Flysky ct-6b. I took the case off, heatshrunk it and ground the servo connectors shorter so the wires could bend sooner.
