Hmm, you could have the wing warp if you use balsa and plastic cover, right? I guess with foam it's going to be more complicated because you can't really twist it...
As for the moving wings, what kind of torque and precision would you need? I'm running outrage torq
BL9180 (17 kg-cm) on my Goblin 700 helicopter on the cyclic, and
BL9188 (6 kg-cm) on the tail. Very good resolution, I don't know what kind of speed you would need though... Would that kind of torque be enough? If you need only little movement, you can move the control rod to the inside of the control horn for more power/resolution.
As an extra, you could have 2 of those servos in a pull-pull setup, but that's going to be horrendously expensive. I can build 4 planes for the cost of 1 of those servos, and my Goblin uses 4 of them...
