L Edge
Awhile back, canards interested me as to what they can do and their design limitations. Interesting stuff. Did quite a bit of exploring and dreamed up this one to see what would happen. Why can't they be used as elevons? Went hunting for research data and in the Langley facilities, found that work was done in the spin tunnel and it is possible. In summary, they felt it would work, but the weight factor to handle the stresses would outway it's avantage.
So, took my trusty old F-22, 2 h-55 servos and just glued then onto the horizontal fuse so the canards cleared the main wing. So, now the rotational point is about 1/4 " above the fuse. The canard is designed to have 1/2 area above the rotational axis and the other below. That is to try to reduce stress on the servos. Used 2 mixes to be able to control limits of canard elevons. If you view the video, elevon motion is shown first and just for the heck of it, go to 9:30, just see what I did. I didn't even put the servo screws in to see what kind of load is present.
Results:
Found I got an higher angle of incidence before it started rocking.
The F-22 responds a lot quicker in doing rolls and loops and turns.
When in tight turns, the nose doesn't tend to drop down in either left or right turns.
Does it work, heck yes!!!
What machine do you know of that has 2 motors, differential thrust, 2 sets of elevons that exits with these functions.
It took me about 3 seconds to come up with a modified planform (DeltaStorm) and what I wanted to do with it.
By the way, I drank 5 cups of coffee before each flight to handle this monster.
Any questions?
Results:
Any questions?
