This is what shows up when I plug in a new USB cable:
Apr 12 19:51:22 JFTMBP kernel[0]: 045417.895257 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:22 JFTMBP kernel[0]: 045417.895282 PRT1@14100000: AppleUSBHostPort::resetGated: unrecoverable enumeration failure after 8 attempts
Apr 12 19:51:25 JFTMBP Screenhero[4264]: JS Log: Strophe (1): _dataRecv called
Apr 12 19:51:36 JFTMBP kernel[0]: 045431.050126 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:36 JFTMBP kernel[0]: 045431.050152 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 100 ms
Apr 12 19:51:36 JFTMBP kernel[0]: 045431.383896 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:36 JFTMBP kernel[0]: 045431.383921 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 200 ms
Apr 12 19:51:36 JFTMBP kernel[0]: 045431.948255 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:36 JFTMBP kernel[0]: 045431.948277 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 400 ms
Apr 12 19:51:37 JFTMBP kernel[0]: 045432.975915 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:37 JFTMBP kernel[0]: 045432.975937 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 800 ms
Apr 12 19:51:39 JFTMBP kernel[0]: 045434.876463 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:39 JFTMBP kernel[0]: 045434.876484 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 1600 ms
Apr 12 19:51:43 JFTMBP kernel[0]: 045438.516426 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:43 JFTMBP kernel[0]: 045438.516449 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 3200 ms
Apr 12 19:51:50 JFTMBP kernel[0]: 045445.691490 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:51:50 JFTMBP kernel[0]: 045445.691510 PRT1@14100000: AppleUSBHostPort::resetGated: retrying enumeration in 6400 ms
Apr 12 19:52:04 JFTMBP kernel[0]: 045459.880259 PRT1@14100000: AppleUSB20XHCIPort::resetAndCreateDevice: failed to create device, disabling port
Apr 12 19:52:04 JFTMBP kernel[0]: 045459.880280 PRT1@14100000: AppleUSBHostPort::resetGated: unrecoverable enumeration failure after 8 attempts
So I'm guessing the machine recognizes that something has been connected to the USB port, but I'm not familiar with this readout. Does this indicate that I have a data cable? I just purchased a new micro USB data sync cable. Is there anything I can see on the cable/pins itself to determine the correct cable...if that's even the problem? I don't want to buy a bunch of cables if it's a software issue.
