OK, I've run into a frustrating problem with my Gremlin. I first noticed that, in acro mode, I have to continuously push the pitch stick forward to keep the quad from nosing up. Then I tried an experiment. I got the quad hovering in self-leveling mode, then switched to acro mode. I applied throttle while the quad was still hovering level, and the nose pitched up again. This happens regardless of how aggressively I apply the throttle, though more aggressive applications make the nose pull up more severely.
I've tried adjusting the anti-gravity settings in Betaflight, and I've adjusted both the P and I terms on the pitch axis. I've recalibrated my sticks. I've adjusted the CG by pushing the battery forward.
I'm out of ideas. Does anyone have any suggestions?
Thanks.
Thanks.
