Cumbersome_Dinosaur
Hey everyone, just wanted to share some thoughts about the Carbon Cub S2.
Overall, I love this airplane and there’s not a whole lot to complain about. I bought the RTF version and installed flaps. I would consider myself to be an “advanced beginner.” I wouldn’t bother buying any of the GPS stuff or landing sensor because the SAFE seems to give enough assistance for landings.
Batteries- the airplane came with a 2200mah smart battery and I would suggest buying more. I get about 5-6 minutes flying time on 2200mah batteries. I bought a bigger 3200mah battery and it flies just fine; I actually like the characteristics the airplane has with a little more weight. I get about 7-10 minutes out of the 3200mah battery. This is also me flying fast and aggressively.
Landing gear- the landing gear IMO is kind of weak and bends a lot on landings. also bare in mind most of my flying is on dirt or rough grassy areas which seems to be rough on the landings also.
Flaps- quite honestly they’re not really needed. I put them on mainly because I like tinkering and wanted to see what they were like. Takeoffs are definitely quicker but I don’t think they help much for landing; the plane actually sort of stalls out and falls to the ground at around 3-5ft. It’s a little helpful tho when use the larger battery because of the weight, but I still only use the takeoff flaps for landings. Full flaps are about useless. I had one instance where I was screwing around with full flaps just sort of floating around and flipped it in beginner mode; it seemed to confuse the SAFE and it started spiraling nose down to the ground but I was able to recover.
Flight modes- I spend most of my time in the air on experienced mode because I like the freedom and I want to build my pilot skills. If I become disoriented, I usually flip it to beginner mode and it will correct itself. I still do all of landings on beginner mode and will eventually attempt on expert.
Durability- this airplane holds up pretty well. So far I’ve only replaced the prop. I did make some repairs to the tail and reinforced the hinges with packing tape because they were starting to rip. The rudder started to break from flipping over on landings (not a pretty repair, but flies fine until the replacement arrives-see photo). I’ve already mentioned the landing gear. I may try to do some mods in the future to fix these things.
I’m not sure I would recommend this airplane for a first time flier-I would wait a few flights. I learned on my F959 glider which I think helped me learn to “feel the air.” If any one has any questions, let me know!
