CARBON FIBER DISCUSSION
Are u gonna put a flight controller in it or no and what gps are u using ?
Yes I am using a FC and a drone GPS for tracking the speeds....I don't actually run my controls through the FC because i feel like I have less control...But I transmit the speeds back to my FPV goggles which are then recording the speeds which I can then sync in the timeline to give me a live speed on my videos like I did in this one!
Zoom Master
Hmm good idea !
Zoom Master
So after spending and hour or 2 give or take in fusion yesterday this is what I came up with for the carbon pylon.
Zoom Master
Wow, Looks much better than your other ones! I think if wing mount was designed properly, that could be made from Foamboard too….
Yes I know it looks 10 times better then my foam board ones and yes if I’m able to make a nice mount for the wing I could make it out of foam board no problem I’ll start designing the wing mount.
Zoom Master
Thank god I haven’t built the foamboard planes yet because I’m gonna go and redesign the fuselages of all of them 😂
telnar1236
Your best bet might be to use a hot wire cut compression mold. The wing should have a foam core regardless for weight reasons, and by hot wire cutting you get both the female and male sides of the mold. You can bondo and sand the female halves of the mold then paint it with primer and a release agent to make something that will give you a good surface finish. Then you wrap the male side in CF cloth with resin and put it back into the female mold and put a bunch of weight on top of it to force out the excess resin. Not as good as vacuum bagging it but a lot easier and it doesn't require equipment beyond a hot wire cutter which is very easy to make. So, the foam block would end up being cut something like this.
Mylar security blanks can make a good release film which gives a very shiny surface with fiber glass (you wrap this around the lay up before putting it in the female mold instead of using PVA or similar) but I haven't tried with carbon fiber. You also have to watch out to make sure the resin you're using won't melt the foam you're using.
It's also probably a good idea to build whatever design in foam board or even to 3D print it since you've got the fusion files before starting on the composite one. Means you can catch the issues early and not after spending 10s of hours on a lay up.
