This could be a fun show/challenge. It's 1944. you're returning from a strafing run in your corsair and you're low on fuel. The carrier is is about 10 miles ahead but you may not have enough fuel if you don't catch the arresting cable on the first try. Can you keep from going into the drink?
Make an 'aircraft carrier" out of two sheets of plywood to create a 16 x 4 foot deck elevated about two feet off of the ground. Stretch rubber bands across the back of it for arresting cables. Try landing on it with mighty mini corsairs modified with landing gear and an arresting hook. For even more excitement try it FPV
Also you had to get into the air somehow. Create a catapult system in the front of the "carrier" to launch your corsairs from the deck.
Just a Plane Dude
Just a Plane Dude
