Help! CC2500 FPV help
Hi, I recently got the CS2500 transmitter and a FPV pan/tilt. Can anyone help me figure out how to configure this: Uses three position switch (SC) and a rollar (S1). When SC is in its neutral position S1 does not move any servos. When SC turns to position 1, S1 controls pan. SC turns to position 2 then S1 controllers Tilt (Tilt does not have any up, just 180 degress of down) Any help would be appreciated!
So the problem you are having is when you switch the 3 position switch one way the tilt works and when you turn it the other way it doesn't?
Maybe give us the make and model of the pan/tilt and radio so we have a better idea of how to help. Pictures are always good too. CS2500 is the TX chipset, but does not tell us much about the transmitter.
Cheers
