Zoszko
Hello everyone!
I have just built my 250 FPV today, it was quite easy and straigth forward. It came with a CC3D, I have followed the wizzard and configured it. It does fly but I am having problems with it staying in place. Once I give it enough throttle to lift off it will start moving to the right or to the front.
I have only tested in indoors so I am guessing it could be the problem as the air it sucks in has an angular momentum and that messes up things. (like on turbines, angular momentum is used to controll it's speed so it might have some effect on the quads lifting as well) So I guess my problem will be solved once I can get it to a bigger open space.
The other thing is, when I want to rotate it (YAW) it start to roll and stuff so I have to put it down before it crashes. Is there anything I have missed during the setup or this have to behave like this.
I am using the FS-i6 trasmitter, and the VRa pot to select the flymode (the silly remote does not save my settings once I change the auxilary channel. Ideas on this?) And the 3 modes are Stab 1/2/3.
I have not flown anything before, so I am aming for the best - foolproof - setup.
~Zoszko
~Zoszko
