CC3D Issues???? I think
JordanEvans
Hello I am new to this whole quad thing. I have bought an arf quad(Redcon Phoenix 210) and I am having a some issues. I got it today and plug it in and it had libre pilot on it. I got it setup and every thing worked except that on motor spun backwards not that hard to fix. I then downloaded beta flight so I could configure things more easily and now only one motor spins up and the other three do nothing else. Pls Help.
FredOfMBOX
When you remove the props (always when working on the bench), and connect to betaflight. Can you use the motors tab to spin the motors individually? You have to click the little warning on the right first, and then you should be able to spin up each motor individually.
If that doesn't work, then you likely have a wiring problem. Do you own a multimeter?
JordanEvans
Yes when I do use the individual motors tab each motor spins up. This is what I find weird and cant figure out the issue.
