After marking the firewall and the mounting points for the engine I drilled some holes, installed some T-nuts, and tried installing the engine.
.....and found out I mis-measured the mounting post requirements, I actually need slightly longer posts. The engine sort-of fits right now, but the prop is a little too close to the cowl and the cylinder head cooling fins touch the nosewheel mounting screws. I'll build a simple base to move the engine out slightly and the problem will be solved. Either way, it's a great feeling seeing a motor in it! When the spacing is finalized I can do the job I'm really dreading - installing the throttle servo and pushrod. It's really going to be a pain as the servo needs to be moved to the other side of the fuselage.
Note the cowl mounting holes around the outside of the firewall. Most of them are stripped out and in pretty rough shape, so those will need some attention as well. The other option is to leave them and drill all new holes for the cowl, but that would leave a bunch of empty holes in the cowl. No easy solutions on that one, it'll be a lot of little fiddly work to make it all work. I'm considering adding some blocks to the firewall that I'd bolt the cowl to, which would let me move the cowl forward a bit. That would also require even longer spacers for the engine, but it would look a little better as right now the cowl looks like it's mounted too far back.
A 20 x 10 prop looks right for this size plane, and it's also one of the recommended sizes for this 58cc engine. It'll easily swing a 22" prop, but that may be long enough that it cuts grass which I'm hoping to avoid. Working on the plane with the wings on really helps me get my steps in for the day, as no matter what tool I need it's on the other side of the bench forcing me to walk all the way around!
This plane has 9 servos: throttle, 2 for ailerons, 2 for elevators, rudder, steering, and 2 for flaps. I also need to connect the throttle kill switch to the receiver, run power to the receiver, connect a switch to control the lights, plus who knows whatever else comes up. I could run the elevator and aileron servos on a Y-harness to free up spots on my 8-channel receiver, but am not a fan of that with such a big plane. I have an extra 8-channel receiver from FrSky so I'm going to look into connecting them to give me 16 channels. I think I heard somewhere along the line that I could split some of the critical servos between the two giving me some degree of control if one of the receivers dies. Or maybe I'm wrong...
Although I don't yet know the true CoG recommended for this plane yet I think I'm going to be in good shape using a few less pieces of lead than it came with. Making an educated guess shows it just a tiny bit tail-heavy currently. One the exhaust & cowl are installed and the engine moved forward slightly it should be even closer. Those two pieces of lead weigh more than the flying weight of some of my planes!
Wilsonman, that big Xoar prop was $5 at a swap meet. Thanks for the recommendation on using them, they're fantastic props!
