Wes Vasher
I'm building a Cessna 152 swappable from plans I got off of the hippocketaeronautics.com website. The wingspan is about 1100mm. I've stopped used the powerpod's locator pins, instead I just use a second skewer in the front and some foam to keep it centered. I also build in side and down thrust into the powerpod mounting plate. No rudder or landing gear. 3 degrees of diehedral and the wing has a spar made from 6 strips of foam board which I have found holds up against high wing loading without failure. I'm going to add some faux struts too and draw on the windshields.
