kiteboarder
Last summer I built a regular FT Versa Wing. I loved. I recently took it apart to used the hardware in a fresh new Blunt Nose Versa Wing. Both Pushers.
However, I had problems with the CG on the first one, and I'm having the same problems on the blunt nose. Tail heavy.
For the regular Versa, because of the lack of space, I had to add small lead deadweights to the nose (an extra 20g). I was finally able to balance it out using those and a 2200 (240g). Total 260g).
However, with the extra space of the blunt nose versa, I figured I'd run a bigger battery instead of the added dead weight.
However, to balance it out properly, I calculated I need a battery that's around 340g - 360g! That's 4000Mah territory right there and I'm having a hard time finding one that's 20mm thick - As that's the biggest it'll fit. So I'm having a harder time balancing out the blunt nose than I did with the regular versa.
Regardless, I think I can get it done. This blunt nose versa will have no FPV or GoPro, so the battery needs to balance it out.
Am I on the right track? Can you point out a few 20mm thick big and heavy batteries? Any other suggestions to solve this problem?
