Simple Test Completed
How a bout a simple test?
With the plane switched on but sitting on the ground does the elevator move (it only needs to be a slight down 'twitch') when you switch from beginner to expert more?
Well I don't want to steal from Beavis' thread but as I indicated above I seem to have the exact same issue (at least the symptoms are the same). Hopefully you can help both of us simultaneously. (Make sure your seat-belt is securely fastened and return your tray to the upright position.
I did the simple test on both my Sport Cub S birds and got the same result from each one. (I'm assuming you meant for the tester to activate the SAFE system with a quick blip of the throttle because otherwise the control surfaces do nothing when switching between modes.) When you move to Intermediate or Expert mode the elevator moves slightly upward. Also the ailerons do a bit of a twitchy movement - however they move in opposing directions, which I assume, tells me that the surface the plane is resting on isn't quite level.
I'm also a bit confused about the COG. I read an excellent post by Wanderlust in the thread entitled "
CG Marks" (the entire thread is good) but I'm still confused. In this thread Wanderlust said:
Actually, you need to get the centre of aerodynamic pressure (which isn't quite the same as the centre of lift, but it's close) behind the centre of gravity.
Think about a dart: heavy streamlined bit at the front, light draggy bit at the back. Whenever an object is moving through a fluid (think of gasses as extra-thin fluids), it will tend to rotate to place the CoG in front of the CoAP. If the CoG is behind the CoAP, the plane will try to fly backwards.
So why not put the CoG at the nose and CoAP at the tail? Because the control force required to disrupt stability and manoeuvre is proportional to the distance between the two. If your CoAP is too far back, you don't get a plane; you get a lawn dart.
For maximum controllable manoeuvrability, you want CoAP right on top of CoM. But manoeuvrability and stability are in tension; maximum agility equals minimum stability. So, usually, the CoAP is pulled back a bit from the CoG. The more trainer-focussed the build, the greater the CoG/CoAP offset.
The FT guys place the CoG mark where it is when they build the plane, with the CoAP unmarked, but presumably somewhere behind it. But when you build at home, you may use heavier foam or servos or just more glue, which can shift the CoG from where it was intended to be. This is what the CoG marks are for; once you finish building your plane, you need to move weight around until the CoG is where it was designed to be. Often all this requires is to shift your battery a smidgeon.
I wasn't able to find where the manufacturer has published where the COG is supposed to be, but with the battery installed both of mine the COG is about 1.25" behind the leading edge. However without knowing where it is supposed to be, this really doesn't tell me anything.
As far as trimming, I've tried to stick with mechanical at this point, especially since the issue is huge...there's no way a little electronic trimming will correct this issue. (I mean it's night and day when you switch out of Beginner mode - it immediately wants to nose dive.) I've tweaked the control rods to get the surfaces as neutral as possible. When doing this I raise the tail of the plane about 1.5" to simulate actual level flying.
I'm beginning to think it's user error. As a newbie I tend to fly a bit slower than most probably do and I wonder if that is causing the dive. However when I've switched to Expert I am around 50% throttle, so I'd think it would be OK..?
Any recommendations?
Thanks!
