charging through the balance tap
fred0000
#3
why didn't I just think of looking at wire guage/amp rating.
thank you, I plan to charge only at 2-2.2a should be good to go. open to any other feedback though.
#4
I'm charging multiple LIPOs at the same time and only 1 is connected to the charger with the regular leads - all the others are being charged thru the balance ports. I have been doing so for a long time...
Currently charging 3*1300mAh and 2*2200mAh on 2 chargers :)
It takes the same time as charging 1 LIPO - just add upp all mAh, set your charger and press GO
fred0000
#5
great.... the main quesion is how many amps do you charge at? I know you can charge through the balance taps or I wouldn't have asked this question.
