altbob
I'm getting a little better at the whole "groups" and "component" thing..by far my biggest problem are edges that refuse to form into faces, or faces that suddenly disappear when I am editing edges where the polygon looks closed yet somehow isn't. It's frustrating as all get out that Sketchup can't give better info/feedback to help users locate and correct these problems. Maybe the Pro version has some of this funtionality now. I'm just using Sketchup 8, which is the free version that everyone uses, and had to resort to redrawing a few parts to get around this and not go insane...
So back to Chitty, I now have all the parts done on and placed flat on two virtual foam boards. As you can see in the attached photo, I've cut out sections of the chassis to make the model as light as possible (especially the back half), cut a rudder out of the rear/trunk of the car, reduced the size of the front canard, made tabs to hold the canard in place which will allow me to experiment with its incidence (I'll try this both flat and with a 1 degree up angle if I need more lift in front...), and added enlarged Elevons to the rear stabilizer with tabs to hold that in place and a cut-out for the rudder to move. The wings are designed to have 5 degrees of dihedral. With their sweep, this should actually be the rough equivalent of 6 percent, which I hope will make it stable in roll. More dihedral than that and I think I'm asking for trouble. I'm not completely sure how to attach the wings at this point, but I'm planning on inserting them together in the airfoil-shaped slot on the chassis and using a bit of stiff, V-shaped wire on the final model to hold them up at the 5 degree angle. Tabs will probably be added at some point. I also imagine I will need some type of formers to hold the canard and rear stab at exactly 90 degrees. I need to do some research on how these foam board models are put together. This is my first attempt...
Having done all of the above, I'm going to make another proof of concept model now, resizing Chitty to work with a tiny pusher prop, namely the PowerUp Electric Paper Airplane Conversion kit:
http://www.amazon.com/PowerUp-Elect...81531&sr=8-2&keywords=power+up+paper+airplane
A 6" long Chitty model should put the balance point of the PowerUp right at the top curve of Chitty's wing, which I think is pretty close to where the CG should go. We shall see. Given the very unconventional shape of this airfoil, that's a guess as to where the CG should be.
I probably won't get time to actually cut paper and assemble all this until the weekend, so if someone out there in FliteTest land can help me more accurately figure out where the CG should go on Chitty's wing, you would have my everlasting appreciation! FWIW, here's the formula: MAC = rc x 2/3 x (( 1 + t + t2 ) ÷ ( 1 + t )) - Good luck with that!
Seriously, between the front taper, the rear sweep and the bat-like trailing edges, finding the mean aerodynamic chord on this wing is perhaps one of the biggest challenges for me at this point. Any help would be appreciated! I'm happy to email the Sketchup file of the wing components to anyone (or any other parts for that matter). Thanks!
