Hi All ( and thanks in advance )
I have some multi-rotor parts and I need some help on which direction to go.
My goal is flight time (mixed hover and movements) at reasonable speed with gimbal and gopro.
The parts I have and or plan to buy are:
Radio: (waiting for delivery)
transmitter FRSKY X9D plus (hardware B01 intentional)
receiver FRSKY X8R (intentional) (waiting for delivery)
FC - Fligth controller: (own it, and tested OK)
PIXHAWK + GPS + POWER MODULE + 900MHZ radio modem telemetry + buzzer + switch.
FPV: (own it, and tested OK)
transmitter 5.8GHz 32CH A/V 600mW Transmitter (TS832) (all ready own it)
receiver 5.8 GHz 32 Channel RC832 (all ready own it)
Micro MinimOSD
7 inch screen with no audio
Gimbal: (plan to buy)
HAKRC Storm32 3 Axis Brushless Gimbal W/ Motors & 32 bit Storm32 Controlller for Gimbal Gopro3 / Gopro4 FPV Accessory
2 Frames:
OPTION 1 (waiting for delivery) : Tarot 650 Carbon Fiber 4 Axile Aircraft Fully Folding FPV Quadcopter Frame Kit TL65B01 F05548
OPTION 2 (already own it) : Tarot FY690S Full 6 axle Carbon Aircraft Frame 3K Folding Hexacopter 680mm FPV TL68C01 F07803
Battery (already own them):
2 x Turnigy nano-tech 5000mah 4S 25~50C Lipo Pack
ESC (already own them):
4 x AFRO 30A opto
4 x AFRO 30A non opto with bec
MOTORS (I currently have):
4 x sunnysky v2216 900KV (http://www.rcsunnysky.com/html/2014/vseries_0918/23.html)
6 x DT750 (at least one motor is a bit loose)
PROPS (I currently have):
GEMFAN 1045 Nylon Propeller CW/CCW
Now here is where I need your help ( I have spent to much time and money doing the wrong things
While I prefer to use the TL65B01 (4 Axile) frame with the motors I already have (sunnysky v2216 900KV with 10x45 props), my understanding is that the flight time will be bad.
I am interested In buying proper new motors or additional motors and new props.
option 1: TL65B01 (4 Axile) with sunnysky v2216 900KV and different props.
option 2: TL65B01 (4 Axile) with diffrent motors and different props.
option 3: TL68C01 (6 Axile) with sunnysky v2216 900KV and buy 2 more motors and different props.
option 4: TL68C01 (6 Axile) with diffrent motors and different props.
option 5: TL68C01 (6 Axile) with DT750 motors and different props.
List of motors I was looking at are ( really confused as data is not really available ):
1. Sunnysky X3108S 720 KV
2. Sunnysky X3508S 580 KV or 700KV
3. Sunnysky V3508 580 KV or 700KV
4. Tarot 4006/620KV Multi-axis Brushless Motor TL68P02
5. Rctimer 5010-620KV Multicopter Brushless Motor
6. DJI E600 3508 MOTOR motor and DJI 12*4.2 props
7. DJI E800 3510 MOTOR motor and DJI 13*5.5 props
Any other recommendation will be great.
About the props, above all they should match the motor and frame but I would also like them to be self-lock and quick release ( I really like the DJI E600 and E800 props and motor mount but I am not sure if I can use it on non DJI motors)
Many Thanks TechSgin
Micro MinimOSD
2 Frames:
4 x AFRO 30A opto
