Help! CHOOSING A ESC
Zoom Master
ChatGPT said 8mm bullet connectors are best for really high amps BTW.
8mm is probably not a good idea as the wire is to thin yes 8mm bullet connectors can handle 200 amps but my wires will become hot enough to cook a steak and again my motor is pulling a max of 120 amps for like 10 seconds so I can get away with using a 4mm bullet connector for the motor and a 7mm bullet connector for the battery.
No they won't because they are rated for 200a.
Zoom Master
Ok assuming they wont ill get some 7mm bullet connectors because 8mm is a bit overkill considering im not pulling that many amps and according to the motor company im buying from with a APC 7x7 prop and on 6s ill be able to pull 120 amps at full throttle for a max of 6-7 sec.
But what if you want to use a more powerful motor in the future...Then you will already have the connector that you will need!
Here's some!
