I designed and built these motor mounts. Shown in the photos, but not included, is the HobbyKing AX-2810Q motor. This has a standard bolt pattern for 19mm x 16mm. I can create any bolt pattern you want. They have 4 countersunk holes for the 3mm screws (included).
They are designed to be compatible with all the rotor bones scratch build frames. They use the same 1/2" square dowel and zip ties used in the flite test build videos.
These are made with G10 fiberglass. You are not going to break them in a crash but if you do I will send you a replacement for free.
QUAD SET - $18 USD
- 4 motor mounts
- 16 screws
- free shipping (lower 48 USA only)
TRI SET - $12 USD
- 2 motor mounts
- 8 M3 flat head screws
You will need your own motor and zip ties.
Please contact me if you are interested. I accept payment via PayPal or offer local pickup (Chicago, USA).
NOTE: I am working on a tricopter tail which I am testing now. When that is done I will offer a two motor mount + tail rotor mount package for those that are interested.
QUAD SET - $18 USD
- 4 motor mounts
- 16 screws
TRI SET - $12 USD
- 2 motor mounts
